Hi Kelley,
The definitive correction would be to change the address position using Report Writer, but that requires some familiarity with RW and is usually done by a Partner. If you want to look at RW, print a report to the screen and click on Modify. If you want to experiment with it, be sure to do it in a Test Company, not in your production data.
But there are other RW considerations also. The user will have to be given security access to the modified version before they can see the printed changes and those changes may only show up on the PC where the mods were created, depending on the location of your report dictionaries.
You mentioned that you don't have IS support, but this should be an easy change for your Partner.
Cheers and happy holidays!
Don McCready
The Schaefer Group, Inc.
Beavercreek OH
Sent: Dec 25, 2020 08:26 AM
Subject: Check template
Purchasing - When our vendors have an address with 4 lines, the final line is printing too low on the check. Is there an easy way to fix this? We don't have IS support.
Kelley Karl
Professional Assist Corp
Golden CO
