v18.3 upgrade causes issue with PM HATB report
  • 1.  v18.3 upgrade causes issue with PM HATB report
    Posted Nov 13, 2020 07:37 AM
    We had 3 support cases this past week where clients reported that their PM HATB reports have changed after they were upgraded to GP v18.3. They had run the report prior to upgrading and then ran the same report with the same parameters after the upgrade and the 2 reports do not match even though no transactions have been entered. We opened a support case with Microsoft and @Terry Heley responded with this:
    We actually have tested this and found an issue with this feature:
    Microsoft Dynamics GP Fall 2020 – Remove MC Fully applied documents from PM HATB
    I will update the blog with the workaround, but what you need to do is use the 18.2 proc and it will fix the issue.
    We will fix this in the US year end update due out 11/20/2020.
    ​​​So if this is happening to you, you are not crazy! And thank you, as always, Terry!
    Barbara Gavron
    904-536-0129
