  • 1.  Who update the price of Items
    Posted Aug 31, 2021 12:08 PM
    Hello Folks, I have had a couple of instances where the Item Maintenance has been updated with the wrong prices. I would like to have a way to identify who updated the item maintenance last. Does GP store somewhere when and who made the last price update? if so, in which tables are these data stored?
    Thanks in advance for your help.
    Kind regards,
    Sam Lyra
    Samuel Lyra
    Trudell Medical Limited
    London ON
  • 2.  RE: Who update the price of Items
    Posted Sep 01, 2021 01:00 AM
    Hi @Samuel Lyra
    GP does not be default keep track of old data. There is some audit trail capabilities in GP which can be enabled, but they will only tell you that a user saved a record and not what the data was before and after.
    I recently published free examples using GP P​ower Tools to track changes on Vendors and Customers.  This concept could be extended for Items
    https://winthropdc.wordpress.com/2021/08/20/gppt-tracking-changes-to-customer-and-vendor-cards/
    It won't go back in time for you, but could easily provide the data you want in the future
  • 3.  RE: Who update the price of Items
    Posted Sep 16, 2021 11:48 AM
    Hi Samuel,
    If you have activity tracking enabled in GP, you can use the following script:
    SELECT act.CMPNYNAM, usr.USERNAME, act.DATE1, act.TIME1, act.SECDESC,
    CASE WHEN INQYTYPE = 1 THEN 'user login failed' WHEN INQYTYPE = 2 THEN 'user logging in' WHEN INQYTYPE = 3 THEN 'user accessed form' WHEN INQYTYPE = 4 THEN 'user login denied' WHEN INQYTYPE
    = 5 THEN 'user accessed report' WHEN INQYTYPE = 6 THEN 'user denied report' WHEN INQYTYPE = 7 THEN 'user added master record' WHEN INQYTYPE = 8 THEN 'modified user master record' WHEN INQYTYPE
    = 9 THEN 'deleted user master record' WHEN INQYTYPE = 10 THEN 'user process server used' WHEN INQYTYPE = 11 THEN 'user added utility record' WHEN INQYTYPE = 12 THEN 'user accessed file maintenance'
    WHEN INQYTYPE = 13 THEN 'user file denied' WHEN INQYTYPE = 14 THEN 'user accessed routines' WHEN INQYTYPE = 15 THEN 'user logged out' WHEN INQYTYPE = 16 THEN 'user Went into modifier' WHEN
    INQYTYPE = 17 THEN 'user went into report writer' WHEN INQYTYPE = 18 THEN 'user added transaction record' WHEN INQYTYPE = 19 THEN 'user deleted transaction record' WHEN INQYTYPE = 20 THEN 'user modified transaction record'
    WHEN INQYTYPE = 21 THEN 'user added setup record' WHEN INQYTYPE = 22 THEN 'user deleted setup record' WHEN INQYTYPE = 23 THEN 'user modified setup record' END AS InqType
    FROM DYNAMICS.dbo.SY05000 AS act LEFT OUTER JOIN
    DYNAMICS.dbo.SY01400 AS usr ON usr.USERID = act.USERID
    WHERE (act.USERID LIKE '%%') AND (act.SECDESC LIKE '%item master file%')
    ORDER BY act.DATE1 DESC
    Aref Karam
    Data Consultant
    LTI Information Technology
    Ann Arbor MI
