Negative POP10110.LineNumber
  • 1.  Negative POP10110.LineNumber
    Posted Nov 10, 2020 11:16 AM
    Good day, everyone!
    I am working with a customer who came across an issue that I am not able to reproduce but have been told has happened before.
    There are a number of PO lines (in the POP10110 table) that show the LineNumber as a negative.  The top query results are from a production database showing the negative number.  The bottom query results are from a backup of that production company.  As you can see, these values were originally what one would expect to see.  There are over 700 POs that this has occurred to.
    Negative LineNumber
    Has anyone ever seen this before?  If so, do you happen to know what the cause is?  A reconcile does correct the issue but we are trying to understand why it happened in the first place.
    Jamie Evenson
    CEO
    Najaxa Software
    Fargo, ND
  • 2.  RE: Negative POP10110.LineNumber
    Posted Nov 13, 2020 03:24 PM
    Hi @Jamie Evenson ,
    The only time I've seen something similar happen is when a client had someone else write a custom integration to create and update/modify  the PO.  They were using some wonky calculations in the integration that would cause the "update" part of the run to change the numbers and sometimes they turned negative.
    Any chance you've got customizations that interact with the PO on some level?
    Samantha​
  • 3.  RE: Negative POP10110.LineNumber
    Posted Nov 16, 2020 10:12 AM
    Hi @Samantha Higdon,
    Thank you for your response.  This customer definitely has a customization (written by Microsoft many, many years ago) ​that does update/modify the PO.  I will look into this and see what it might be doing with the Line Number.
    Thank you again for the suggestion!
    Jamie Evenson
    CEO
    Najaxa Software
    Fargo, ND
