Econnnect Error on GP2018
Jump to Best Answer
  • 1.  Econnnect Error on GP2018
    Hi,
    We have just upgraded to GP2018 from GP2018.
    We are getting errors on Econnect integration.
    Dynamics GP Accounts Payable Exception: Microsoft.Dynamics.GP.eConnect.eConnectException:
    The EXECUTE permission was denied on the object 'taUpdateCreateVendorRcd', database 'XXXX', schema 'dbo'.
    Dynamics GP Accounts Payable Exception: Microsoft.Dynamics.GP.eConnect.eConnectException: '', hexadecimal value 0x02, is an invalid character. Line 1, position 481.
    at Microsoft.Dynamics.GP.eConnect.ServiceProxy.CreateTransactionEntity(String connectionString, String xml)
    Dynamics GP Accounts Payable Exception: OLE IDispatch exception code 0 from .Net SqlClient Data Provider: The SELECT permission was denied on the object 'PM30300', database 'XXXX', schema 'dbo'...
    Dynamics GP Accounts Payable Exception: Microsoft.Dynamics.GP.eConnect.eConnectException: The EXECUTE permission was denied on the object 'taUpdateCreateVendorRcd', database 'XXXX', schema 'dbo'.
    at Microsoft.Dynamics.GP.eConnect.ServiceProxy.HandleSqlException(FaultException`1 ex)
    I tried running Grant,sql on company database as well as DYNAMICS database but it didn't work.
    I appreciate all the help
    Umit Ciltas
    Applications Manager
  • 2.  RE: Econnnect Error on GP2018
    Hello Umit,
    Did you do an in-place upgrade or did you migrate to a new server?
    If you are on a new server, the first thing I would do is verify all of the code in your integration points to the new server.  You may have something like a SQL stored procedure or view that has the old server name hardcoded.  Then I would verify the SQL permissions of all of the accounts that are associated to your integration (i.e. the logon for the service:  eConnect for Microsoft Dynamics GP 2018 Integration Service).
    Healthmark Industries
  • 3.  RE: Econnnect Error on GP2018
    HI Chris,
    We upgraded on a new server.  So we had to move the logins and restore the databases on the new SQL server.
    SQL 2017 on Win 2016 box.
    I will double check the integration connection again but connection is successful.
    Stored procedures are all original ones from system so we did not develop them.
    I have realized some of those stored procedures are encrypted.
    I have not checked the econnect service account but I will verify that
    Thank you
    Umit
    Umit Ciltas
    Kissimmee FL
  • 4.  RE: Econnnect Error on GP2018
    Hi @Umit Ciltas,
    I agree with Mike.  When I've seen errors similar to yours it has been rooted in the SQL permissions of the user that is associated with the eConnect for ​​Microsoft Dynamics GP integration service.
    Running the grant script for that is a good start.  You'll also want to make sure that user has been granted the DYNGRP permissions on the relevant databases.
  • 5.  RE: Econnnect Error on GP2018
    Yes, econnect user is in DYNGRP both in DYNAMICS and company database.
    Thank you
    Umit Ciltas
    Umit Ciltas
    Kissimmee FL
  • 6.  RE: Econnnect Error on GP2018
    Best Answer
    Did your eConnect installer have sysadmin permissions to the SQL Server? Also make sure for the installation time that that person is also a local admin on the eConnect Server location. That way all eConnect pieces are put in place properly. Reinstall or repair the eConnect service if not.
    The other possibility is the eConnect integration code AD User doesn't have the needed GP/SQL access.
    Do your errors on the eConnect Server Event log have the Service account in the error or the Integration User AD account(Current User Name)?
    Event Viewer > Applications and Services Logs > eConnect
    David Morinello
    Ascend Learning, LLC
    Leawood KS
  • 7.  RE: Econnnect Error on GP2018
    Hi David,
    That was it.
    It was not in the company database DYNGRP role.
    It was in DYNAMICS database.
    Everyone was on point and were very helpful
    Thank you for quick response.
    Umit Ciltas
    Applications Manger
    Umit Ciltas
    Kissimmee FL
  • 8.  RE: Econnnect Error on GP2018
    @Umit Ciltas I agree with all of the above.​
    Basically, though, if you are upgrading from one version to the next some tables may change in the Stored Procedures.
    If you are on a new server, does it have a different 'sa' password, and if so, have you installed the right version of eConnect with the permissions for the new 'sa'.
    Is eConnect set to use the users credentials when writing to SQL? If so, you'll need to make sure the users' AD Accounts are all setup on the new/upgraded server.
    Is your eConnect pointing to the new instance, if there is a new instance?
    If you are using a front-end like SmartConnect, have you upgraded SmartConnect to the new version, etc.
  • 9.  RE: Econnnect Error on GP2018
    One other thing that you need to note is that if you have any customized eConnect stored procedures (those usually have a name beginning with 'ta') you will need to re-create those after the upgrade as GP will update them with the out of the box stored procedures.
    Jeff Woodard
    Chief Technical Officer
    West Palm Beach FL
