New York - New Jersey Regional Chapter
Undo bank Reconciliations
  • 1.  Undo bank Reconciliations
    Posted 01-05-2018 04:24 PM
    hi,
    does anyone know if there is a way to undo a bank reconciliation after it's done?
    Yanna Zhang
    Stellar Services
  • 2.  RE: Undo bank Reconciliations
    Posted 02-15-2018 09:55 AM
    You can rollback a posted Bank Reconciliation with the use of a series of SQL queries, if you are comfortable with using SQL Queries:
    If you have copied your production company that includes the Bank Reconciliation you want to roll back to a Test Company, backup the Test Company. With a backup, you can go through the steps a number of times to make sure you are satisfied with the results.
    When you are comfortable that the process will provide the results you want, backup your production company and perform the steps there. (Hopefully, only once)!
    Query 1) Find the RECONUM of the reconciliation to be rolled back with the first query:
              select * from CM20500
              where CHEKBKID = 'ID of your Checkbook'
              order by RECONUM
    make a note of the LAST_RECONCILED__DATE  & the LAST_RECONCILED_BALANCE.
    These will be needed in the last steps.
    2) Reset the RECOND flag, the Cleared Amount and the Cleared Date, and the RECONUM on the transactions included in that reconciliation:
              update CM20200
              set RECOND = 0
              where RECONUM = 'The RECONUM identified by Query 1'
              update CM20200
              set CLRDAMT = 0
              update CM20200
              set CLEAREDATE = 0000-00-00
              update CM20200
              set RECONUM = 0
    3) Remove the Reconciliation from history:
              delete CM20500
    4) Update the Checkbook Master with the revised Last Recon Date and Last Recon Amount:
              update CM00100
              set LAST_RECONCILED _DATE = '2018-MM-DD 00:00:00.000′ (with whatever date is appropriate)
              update CM00100
              set LAST_RECONCILED_BALANCE = 'Beginning amount of the new Reconciliation'
    Michael Peck
    Microsoft Dynamics GP Consultant
    NTT Data
    Croydon PA
  • 3.  RE: Undo bank Reconciliations
    Posted 02-15-2018 10:28 AM
    @Michael Peck thank you so much for the script I have had customers ask for this, but never thought it was possible.​  I am going  to add this to my Nightmare course.  Thanks so much for the information.
    Tanya
    Tanya Henderson
    Senior Consultant
    S2 Technology
    Park City UT
  • 4.  RE: Undo bank Reconciliations
    Posted 27 days ago
    I'm glad it helped.
    Michael Peck
    NTT Data
    Croydon PA
